Tomcat
Tomcat
766次浏览
Apache
Tomcat 服务器是一个免费的开放源代码的Web 应用服务器,属于轻量级应用服务器,在中小型系统和并发访问用户不是很多的场合下被普遍使用,是开发和调试JSP 程序的首选
Apache Tomcat is an open-source Java Servlet Container developed by the Apache Software Foundation, implementing the Jakarta Servlet, Jakarta Server Pages (JSP), Jakarta Expression Language (EL), and Jakarta WebSocket specifications. It serves as a lightweight, high-performance web server and application server for running Java-based web applications. The latest stable release, Tomcat 10.1.x (as of 2024), builds on the foundation of previous versions while introducing enhancements in performance, security, compatibility with Jakarta EE 10, and developer experience. This document provides a detailed overview of Tomcat 10.1.x’s core features, architecture, and use cases.
一、 Core Positioning & Overall Architecture
Tomcat’s core positioning is to provide a robust, scalable environment for executing Java web applications, bridging the gap between client requests and server-side Java code. It implements key Jakarta EE web specifications, enabling developers to build dynamic, interactive web applications with standard APIs. Tomcat can operate as a standalone web server or be integrated with front-end servers like Apache HTTPD or Nginx for enhanced performance and load balancing.
  • Key Roles:
    • Servlet Container: Manages the lifecycle of servlets (init, service, destroy) and handles client requests/responses.
    • JSP Engine: Translates JSP files into Java servlets, compiles them, and executes them to generate dynamic HTML.
    • WebSocket Server: Supports full-duplex real-time communication between clients and servers.
    • Resource Manager: Provides access to JNDI resources (data sources, mail sessions) and shared libraries.
  • Modular Architecture: Tomcat’s architecture is hierarchical and modular, with the following core components:
    1. Server: The top-level component representing the entire Tomcat instance. It manages one or more Service components.
    2. Service: Groups one or more Connectors with an Engine to process requests from clients.
    3. Connector: Listens for client requests on a specific port and protocol (HTTP, HTTPS, AJP). It forwards requests to the Engine and sends responses back to clients.
    4. Engine: The request-processing engine for a Service. It routes requests to the appropriate Host based on the domain name.
    5. Host: Represents a virtual host (e.g., www.example.com) and manages one or more Contexts (web applications).
    6. Context: Represents a web application (WAR file or directory). It contains servlets, JSPs, static resources, and configuration files.
    7. Wrapper: Represents an individual servlet. It manages the servlet’s lifecycle and execution.
二、 Core Functional Modules
Tomcat’s functionality is organized into modules that handle specific aspects of web application execution. Below is a detailed breakdown of key modules:
2.1 Servlet Container Module
The Servlet Container is the heart of Tomcat, implementing the Jakarta Servlet 6.0 specification. It manages the lifecycle of servlets and processes client requests.
  • Servlet Lifecycle Management:
    • Loading: Tomcat loads the servlet class using its class loader (based on the web app’s classpath).
    • Instantiation: Creates a single instance of the servlet (by default, servlets are singletons).
    • Initialization: Calls the init(ServletConfig) method to initialize the servlet (e.g., load configuration parameters).
    • Service: For each client request, a thread from the thread pool calls the service(HttpServletRequest, HttpServletResponse) method, which dispatches to doGet() or doPost() based on the request method.
    • Destruction: Calls the destroy() method when the servlet is unloaded (e.g., app shutdown) to release resources.
  • Thread Pool Configuration: Tomcat uses an Executor component to manage thread pools. Example configuration in server.xml:
    <Executor name="tomcatThreadPool" namePrefix="catalina-exec-"
        maxThreads="200" minSpareThreads="25" maxIdleTime="60000"/>
    Key parameters: maxThreads (maximum concurrent threads), minSpareThreads (minimum idle threads), maxIdleTime (time to keep idle threads alive).
  • Async Servlet Support: Allows servlets to handle long-running tasks without blocking threads. Example async servlet code:
    @WebServlet(urlPatterns = "/async", asyncSupported = true)
    public class AsyncServlet extends HttpServlet {
      protected void doGet(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
        AsyncContext asyncContext = request.startAsync();
        asyncContext.start(() -> {
          // Long-running task (e.g., database query)
          String result = performTask();
          try {
            response.getWriter().write(result);
          } catch (IOException e) {
            e.printStackTrace();
          asyncContext.complete();
2.2 JSP Engine Module (Jasper)
Jasper is Tomcat’s JSP engine, implementing the Jakarta JSP 3.1 specification. It translates JSP files into servlets and compiles them.
  • JSP Compilation Process:
    1. Translation: A JSP file (e.g., index.jsp) is translated into a Java servlet (e.g., index_jsp.java) stored in the work directory.
    2. Compilation: The servlet source code is compiled into a class file (e.g., index_jsp.class) using the Eclipse JDT compiler (default) or javac.
    3. Execution: The compiled servlet is executed to generate HTML output.
  • Precompilation: JSPs can be precompiled during deployment to avoid runtime overhead. Example Maven command:
    mvn tomcat:jsp-precompile
  • EL Support: Jakarta EL 5.0 allows embedding dynamic expressions in JSPs. Example EL usage:
    <p>Welcome, ${user.name}!</p>
    <p>Total items: ${cart.size()}</p>
    Implicit objects: request, session, application, param (request parameters).
2.3 Connector Module
Connectors handle client communication using various protocols. Tomcat supports HTTP, HTTPS, and AJP connectors.
  • HTTP Connectors:
    • Http11NioProtocol: Non-blocking I/O, suitable for high concurrency. Configuration:
      <Connector executor="tomcatThreadPool" port="8080" protocol="org.apache.coyote.http11.Http11NioProtocol"
          connectionTimeout="20000" redirectPort="8443"/>
    • Http2Protocol: Supports HTTP/2 for multiplexing and server push. Configuration:
      <Connector port="8443" protocol="org.apache.coyote.http11.Http2Protocol"
          maxThreads="150" SSLEnabled="true">
        <SSLHostConfig>
          <Certificate certificateKeystoreFile="conf/localhost-rsa.jks" type="RSA"/>
        </SSLHostConfig>
      </Connector>
  • HTTPS Connectors: Secure communication using SSL/TLS. Example configuration:
    <Connector port="8443" protocol="org.apache.coyote.http11.Http11NioProtocol"
      <SSLHostConfig>
          type="RSA"
          sslProtocol="TLSv1.3"/>
      </SSLHostConfig>
    </Connector>
    Key parameters: certificateKeystoreFile (path to keystore), sslProtocol (TLS version).
  • AJP Connectors: Connect to front-end servers like Apache HTTPD. Configuration:
    <Connector port="8009" protocol="org.apache.coyote.ajp.AjpNioProtocol"
        redirectPort="8443" secretRequired="false"/>
2.4 WebSocket Module
Tomcat’s WebSocket module implements the Jakarta WebSocket 2.1 specification, enabling real-time communication.
  • Annotated Endpoint: Example WebSocket endpoint for chat:
    @ServerEndpoint("/chat")
    public class ChatEndpoint {
      private static Set<Session> sessions = Collections.synchronizedSet(new HashSet<>());
      @OnOpen
      public void onOpen(Session session) {
        sessions.add(session);
      @OnMessage
      public void onMessage(String message, Session session) throws IOException {
        for (Session s : sessions) {
          if (!s.equals(session)) {
            s.getBasicRemote().sendText(message);
      @OnClose
      public void onClose(Session session) {
        sessions.remove(session);
  • Key Features:
    • Text/Binary Messages: Support for sending text (UTF-8) and binary (byte array) data.
    • Ping/Pong: Health checks to maintain active connections.
    • Partial Messages: Handle large messages split into chunks.
    • Extensions: Support for permessage-deflate (message compression).
2.5 Security Module
Tomcat provides robust security features to protect web applications.
  • Authentication Mechanisms:
    • Form-Based Authentication: Example configuration in web.xml:
      <login-config>
        <auth-method>FORM</auth-method>
        <form-login-config>
          <form-login-page>/login.jsp</form-login-page>
          <form-error-page>/error.jsp</form-error-page>
        </form-login-config>
      </login-config>
      <security-constraint>
        <web-resource-collection>
          <web-resource-name>Protected Area</web-resource-name>
          <url-pattern>/protected/*</url-pattern>
        </web-resource-collection>
        <auth-constraint>
          <role-name>user</role-name>
        </auth-constraint>
      </security-constraint>
    • LDAP Realm: Integrate with LDAP for authentication. Example in context.xml:
      <Realm className="org.apache.catalina.realm.JNDIRealm"
          connectionURL="ldap://ldap.example.com:389"
          userSearch="(uid={0})"
          userBase="ou=users,dc=example,dc=com"/>
  • Secure Headers: Use HttpHeaderSecurityFilter to add security headers. Example in web.xml:
    <filter>
      <filter-name>HttpHeaderSecurityFilter</filter-name>
      <filter-class>org.apache.catalina.filters.HttpHeaderSecurityFilter</filter-class>
      <init-param>
        <param-name>xFrameOptions</param-name>
        <param-value>SAMEORIGIN</param-value>
      </init-param>
      <init-param>
        <param-name>contentSecurityPolicy</param-name>
        <param-value>default-src 'self'</param-value>
      </init-param>
    </filter>
    <filter-mapping>
      <url-pattern>/*</url-pattern>
    </filter-mapping>
  • TLS Hardening: Disable weak protocols and ciphers. Example in server.xml:
    <SSLHostConfig protocols="TLSv1.3,TLSv1.2" ciphers="TLS_AES_256_GCM_SHA384,TLS_CHACHA20_POLY1305_SHA256">
      <Certificate ... />
    </SSLHostConfig>
2.6 Management & Monitoring Module
Tomcat provides tools to manage and monitor web applications and server performance.
  • Manager App: Web-based interface to deploy/undeploy apps. Accessible at http://localhost:8080/manager (requires manager-gui role).
  • JMX Monitoring: Expose MBeans for monitoring. Example JConsole connection: jconsole localhost:9999 (enable JMX in setenv.sh: CATALINA_OPTS="-Dcom.sun.management.jmxremote -Dcom.sun.management.jmxremote.port=9999 -Dcom.sun.management.jmxremote.authenticate=false -Dcom.sun.management.jmxremote.ssl=false").
  • Access Logging: Configure AccessLogValve to log requests. Example in server.xml:
    <Valve className="org.apache.catalina.valves.AccessLogValve"
        directory="logs" prefix="localhost_access_log" suffix=".txt"
        pattern="%h %l %u %t "%r" %s %b"/>
    Pattern parameters: %h (client IP), %r (request line), %s (status code), %b (response size).
2.7 JNDI Resource Module
Tomcat supports JNDI to access external resources.
  • JDBC Data Source: Example configuration in context.xml:
    <Resource name="jdbc/MyDB" auth="Container"
        type="javax.sql.DataSource" maxTotal="100" maxIdle="30" maxWaitMillis="10000"
        username="dbuser" password="dbpass" driverClassName="com.mysql.cj.jdbc.Driver"
        url="jdbc:mysql://localhost:3306/mydb?useSSL=false"/>
    Access in servlet:
    Context initContext = new InitialContext();
    Context envContext = (Context) initContext.lookup("java:/comp/env");
    DataSource ds = (DataSource) envContext.lookup("jdbc/MyDB");
    Connection conn = ds.getConnection();
  • Mail Session: Example configuration:
    <Resource name="mail/Session" auth="Container"
        type="javax.mail.Session" mail.smtp.host="smtp.example.com"
        mail.smtp.port="587" mail.smtp.auth="true"
        mail.smtp.user="[email protected]" password="mailpass"/>
三、 Technical Features & Advantages
  • Jakarta EE 10 Compatibility: Tomcat 10.1 supports Jakarta EE 10 Web Profile, including the latest versions of Servlet, JSP, EL, and WebSocket. This ensures alignment with modern Java web standards.
  • High Performance:
    • Non-blocking NIO/NIO2 connectors handle thousands of concurrent connections.
    • HTTP/2 support reduces latency via multiplexing and server push.
    • Lightweight JDBC connection pool (Tomcat JDBC) with leak detection and validation.
  • Enhanced Security:
    • TLSv1.3 support for secure, fast communication.
    • Built-in CSRF protection for manager apps and custom filters.
    • Content Security Policy (CSP) and secure headers to prevent XSS and clickjacking.
    • Role-based access control (RBAC) for management apps.
  • Scalability & Reliability:
    • Cluster support for session replication and load balancing.
    • Session persistence to disk/database for server restarts.
    • Fault tolerance: Components handle failures gracefully without crashing the server.
  • Developer-Friendly:
    • Hot deployment of web apps and JSPs for rapid development.
    • IDE integration (Eclipse, IntelliJ) for debugging and deployment.
    • Maven/Gradle plugins for build automation.
  • Flexibility:
    • Modular architecture allows enabling/disabling components.
    • Custom valves and realms for extending functionality.
    • Containerization support (Docker, Kubernetes) for microservices.
四、 Typical Application Scenarios
  • Enterprise Web Apps: CRM systems, ERP platforms, and intranets use Tomcat for scalability and security.
  • E-Commerce: Online stores rely on Tomcat’s high performance to handle peak traffic during sales events.
  • Real-Time Apps: Chat platforms, live streaming, and collaborative tools use WebSocket for real-time communication.
  • Microservices: Lightweight Tomcat containers are ideal for deploying Java-based microservices in cloud environments.
  • CMS Platforms: Liferay, Alfresco, and other CMS systems run on Tomcat to manage dynamic content.
  • Educational Platforms: Learning management systems (LMS) use Tomcat for delivering courses and tracking student progress.
五、 Summary & Official Resources
Apache Tomcat 10.1.x is a lightweight, high-performance, and secure Java Servlet Container that implements the latest Jakarta EE specifications. Its modular architecture, flexibility, and developer-friendly features make it the most widely used Java web server in the world. It is trusted by enterprises and developers for building scalable, reliable web applications.
For more information, download the latest version, or access documentation, visit the official Apache Tomcat website:
